Faunsdale, AL | Pretty hard to improve on a pressure tank, a check valve and a pressure switch. Most anyone can find any one of these and install it on a Saturday afternoon if need be. Not so sure on the variable speed pump!
The size of the pump is going to be limited by the well's recharge rate as well as the size and length of the pipe to the house.
I would also make sure to run the wire to the pump in conduit so you can easly replace if needed without trenching again. | |
