Grand Island, Nebraska | Are there any codes that show in the window under the little flip up door other than "O"? You may need your dealer to hook up the electrical test box that will allow testing of the entire system to determine what is wrong. We have had problems on some with wire connections, but not always the same one. Testing with a good VOM and the test box will help find your problem. | |
