| The 2062 is a different beast. They can be very hard to get adjusted properly for guys that have very uneven and rolling ground.
If you can figure out the manual and follow the directions in order and exactly it can be done by a farmer.
If you are having a dealer tech come out to help, make sure the tech has setup a 2062 head before, it will most likely be a waste of your time and money to have a new tech come out and read the setup manual with you standing there. Also if the head has been setting awhile, settings will change as it loosens up. Good luck, the toughests heads to get set right are the 36 foot 2062's with the offset to the right. | |
