Alsace 47°52'46"N 7°24'30"E | Go to an automotive parts seller and buy a cheapo 12volt.
Do not forget to add an air tank so that you have some reserve.
Make sure that all shut-off automatisms and fuses are OK. Should do the job.
If possible blow up the air tank at the shop. This will add life to the compressor since it won't heat that much.
Be sure to have the air intake in a dust poor place. Dust is poison for compressors.
Should not cost you the fortune you are talking of.
Hope this helps. |
