Posted 3/21/2012 23:00 (#2299755 - in reply to #2299693) Subject: Re: 4920 sprayer
NESD
You can swap the flowmeter cal numbers but I would just swap the flowmeters and see what happens with the rate and pressure first, the cal numbers won't be far enough apart to make a huge difference just to try it, if the rate settles down then swap the cal numbers.
