East central Indiana | You can set alamrs for tank level (low tank) and also set a min flow thru your nozzles. It'll be in your manual. If you dont have one, Im sure you can find one online. As you spray hit your flow/min button and note what it is, and just enter a number around that level, that way it shouldnt drop below that when you slow down, or something I do when doing the outsides of the fields, I will set my rate on manual instead of rate 1 or 2 that way if I want it a little heavy as I slow down, or speed up out of a corner. Just an idea. Ive used Raven 450 and 460 for a long time. Any other questions I'll be happy to help. Also if you dont have a manual, and cant find one, I'll find mine and walk you thru it.
Scott | |
