Posted 1/30/2012 15:43 (#2195232 - in reply to #2195087) Subject: RE: Foam to "wet" with pics
nw pa
try using a big bottle of laundry detergent in each tank, should stiffen up the foam as long as it seems to be working. if that doesn't work then start on the others suggestions. Sounds like it's getting liquid,not enough air. More soap will help.
