Central Ontario | In this picture you can see the air cart has 4 primary lines. The striptill unit has splitters on it to provide the 8 lines for each row unit. Could do same on planter. For a drill you would need 4 towers.
If money isn't an object the newer type air units like Montag, Aluria, Valmar have multiple outlets right at the meter system of the air unit. For a 8 row planter or Striptill you would have 8 hoses come right for the meter system. For the drill you would have to split the 8 lines some how.
Morris has the flat secondary distributors that might work on the drill????
(Air Cart Splitters.jpg)
Attachments ---------------- Air Cart Splitters.jpg (59KB - 55 downloads)
