Posted 3/10/2011 21:22 (#1663286 - in reply to #1662995) Subject: Re: Generator problem on antique tractor
Ontario
did you polarize the generator before you started the tractor? on the ones I have done ,55 chev pu, would not charge. you have to install generator[leave belt off] take the cover off of the regulator and manually close the points and it will make the gen. turn install belt and should be good to go. Rob
