| The second Rightrac arrived today. Installation in a JD sprayer is quite straight forward compared to the steering column on the "Case Steiger" tractors.
The receivers connect to the base station in what seems like a couple of minutes. By the time you plug the base station to the battery and get back to the tractor it is displaying the RT symbol. Unfortunately; saving large fields takes easily 15 minutes and you begin to wonder if anything is happening. I've even lost some data because I became impatient and rebooted the ATC. More later.
