ontario | On our JD 9550 combine we are using the agleader Insight for a yield monitor and the 250 agleader monitor with an ez-steer to guide it. We really like using the Insight for yield monitoring but aren't really big fans of the 250 and ez-steer to guide the combine.
We are looking at a newer JD 9570 that has the JD steering valves in it and we really like the JD guidance but not the JD yield monitoring.
So my question is: can we keep our Insight yield monitor and use the JD steering valves for guidance?
I'm not sure if maybe we can get a Starfire receiver and some JD monitor for guidance and then get a cord to get a GPS signal to the insight...? Or maybe the newer Agleader monitors like the Integra can finally use the JD steering valves....?
Any suggestions are appreciated! Thanks!
