Sunnyvale, CA | The EZ-Steer controller with T2 is a bit sensitive to power on methods. Make sure you start the tractor first, then when the engine is up to speed, turn on the EZ-Steer system. If you crank the engine after turning on power to the EZ-steer system the "engine cranking brownout" might cause the gyros to behave badly. Whenever you have complex equipment work well one day, and the next, work not so well, a power on reset is the first aid action, (just like your Windows PC!) | |
