70 miles north of Dallas, Tx | acfarmer - 8/19/2010 08:22
Wiring harness for the injectors? I had that problem with mine. Would run fine and then sputter and not want to start. Turned out had a bad wire under the valve cover for the injectors.
This is where I would look after checking fuel persure since the tach is moving the CPS should be good.
Deiselstop.com is an excellent Powerstroke site and has been for about 10-12 years. Go to the 94-97 section and post up your problem. |
