NW IA | I noticed the moisture sensor, and the grain flow sensor while checking over the machine but, it wasn't advertised as part of the package, so I didn't expect a monitor of any kind, much less take the time to even look at it other than the model number. I didn't check any further to see if there was a receiver in the machine, because I assumed the antenna connected to the console. I've found all 255 pages of the manual online. A bit overwhelming. Now that I've seen the connection ports, I understand christianh's explanation.
Those of you that are using the EZ500, are using it strictly as the GPS source for the PF3000 which does all of the mapping? | |
