Posted 8/5/2010 21:59 (#1302643 - in reply to #1302623) Subject: Re: mx335 with autopilot
Vidalia ,Louisiana
You also have to make sure to use the correct profile.sometimes when I have had a similar problem I would select an incorrect profile from say a jd unit .
Then choose a correct profile for the correct machine [new from database] and calibrate and fixed the problem.
Sometimes the profile becomes corrupted.
