| So far the insight and direct command has been working pretty well for spraying. I used a minimum flow rate to make sure I have a good pattern when I slow down in tight spots, etc. However, the min flow rate isn't the best idea if I have to shut off some of the boom sections (means more flow through fewer nozzles). When I bought the direct command, it sounded like everyone uses the pressure sensor. Since I already had a readable analog guage, I didn't see the need. Now, however, I'm thinking that setting a minimum pressure would work far better to keep the spray pattern good even with some boom sections shut off. I'm I thinking about this right? Do most new insight/integra (and even raven consoles) use pressure sensors now in addition to the flow meter? How much do they cost?
Thanks,
Pat | |
