| The Dawn model 6000 unit has a design feature that allows you to create aqueous ammonia on the go instead of pre mixing it. You can adjust orifice size on both products and alter the mixing ratio to the desired level. As was mentioned in a previous post mixing the two creates a fairly violent exothermic reaction, e.g. it releases a ton of energy. You would haul two separtate tanks, or more likely some kind of saddle tank with the water. This will definitely dramatically improve sealing in marginal soil conditions. | |
