west central il. | I was the one about ten pages ago that had a problem getting my 2600 to penetrate in the notil. I lowered my transport wheels to top holes. (while down and jack up the frame) It helped a little the guage wheel arms would not be riding on the stops. I ended up using my old JD7000. A rep from Kinze said to put new springs on it. It has 4 per row. I am thinking about eventually adding that ear to the wing with an extra hole. The frame is suppose to be 20" from the ground. My parallel arms are still running down going back, my tongue is also all the way up. The rep said with the springs on the last hole there is 700lbs. pressure. ??? | |
