Western/Central Oregon | I've had both sides of my 8400T rear end replaced and updated. I guess its a real problem for the 00 and 10 series. I guess Deere just needed to work the bugs out of their first series of tracked machines?? Its too bad that we all had to be the testing ground for these little mistakes in engineering. Lets not forget the little mistake about the rockshafts not having grease zirks until the 20 series!! If you use your 3pt a lot as I do, thats one spot that will wear out in a hurry. | |
