Nebraska | did you set the com1 port parameters on the falcon? Falcon needs GGA VTG I set them 19200 3-5 hz 8-N-1 flow Control none
control->Navigation->View->Port set the above numbers hit ok. then go to control->Navigation-> Operate. you should be set up
also try unchecking Enforce Differential, and enforce 3d from the settings button->navigation. this is common with accuracies above waas.
I've never tried the Starfire receiver but it may work. | |
