Search Forums | Classifieds (64) | Skins | Language
JD 8630 PTO problems
Clay-All-Over
Posted 2/10/2010 00:21 (#1067384 - in reply to #1067106)
Subject: RE: JD 8630 PTO problems
Eastern Ontario
Thanks for the info.
I got the same pressures as you. Brake was slightly lower. Brake is located in the rear hinge I believe.
I got the clutch valve housing out this afternoon and couldn't really see any major scoring on the valves. Looked through the side hole to see if anything was visibly wrong with the PTO Clutch, but it looks fine. I will have to tear into it anyways to make sure. I don't have time to dink around with it next fall.
I'll let you know what I find out.
