Posted 2/5/2007 20:16 (#99899 - in reply to #99879) Subject: RE: D5 track adjuster removal
It looked like it was under a scary amount of load. Now you mention the threaded rod I've just realise that the nut retaining the shaft inside the spring goes through a separate end plate, due to rust that all looked to be one piece before. Thanks for putting us on the right track.
