LUMBERTON NC | accually i use that piston in an m farmall as it has the same wrist pin size as the stock m rod has... u rebore the block larger sleeves ...stroke the crank and u can have a yeid of 413 cu in ... i just need some new standard bore pistons arrgh local parts man no help!!! moter size is 4.500 x 6.500 tractor now mkes about 160 hp with all the mods done ... my problem is that this tractor was built in 1992 and has some block issues i am building a new block and want to locate some new slugs for it ... dont want to completely rebuild using a different rod or another stroked crank that more $$$$$$$$$ ... i will keep u in mid with that complete engine my ? is how much does it weigh shipping gotta be pricey ..IHSMOKE | |
