Posted 11/24/2009 10:31 (#936322) Subject: 9750 STS main gear case oil pressure low lite comes on
Central Michigan
For the last couple days on my 03 9750 when turning at times, the steering will get real hard on the main gear case oil pressure low light will come on. Hydraulically everything else works great. steering is only part affected. Changed filters,still does it. Could the steering cylinder be leaking internally, and cause this. Any input would be appreciated. Called Deere dealer, but the hold was so long I hung up.
