Posted 11/7/2009 22:30 (#916529 - in reply to #916482) Subject: Re: 9600 unloading auger problems??
WC Iowa
we had the weld brake on the sprocket the drives that wet unload. From the outside the sprocket was turning, but it was welded to the hub on the inside and the shaft wasn't turning. Took the bolt out, pulled the sprocket and hub off, rewelded it and back to work
Brad
