Windom, MN | Was the header, reel and auger problem corrected??? You obviously have internal leakage but where??? Did the JD tech have a "heat-gun" (not a shotgun) to determine which valve, hyd motor, pump etc was getting the hottest??? Can you hear any hissing?? We've had auger swing limit switches go bad or out of adjustment (wanting to keep folding or unfolding auger) and heating up oil. Try putting auger rocker to center and see if that helps. | |
