WCIN | Biggest problem, obviously, is the bottom is too dry and the top dry enough.
No matter what you do---the bottom will be dryer.
Is your grain level?
What are your plans for this grain? Moving it all at once or some at a time?
Anywho, I would run the fan with a small amount of heat to remove the humidity for as long as it takes to get below 14% at the top.
You don't have to be vicious on the temp at all, but air flow needs to move.
you give some heat, it will help dry them things.
Hope this link works and helps.
http://www.sukup.com/Additional%20pdfs/MANAGING%20STORED%20GRAIN.pd...
If not, www.sukup.com has valuable resourses to base off of. | |
