Tuscola, IL | I have a CIH 2577 Accuguide combine. I took the Nav II out of it to use in a tractor and will not be putting it back in the combine (left all of the wiring on the combine). I moved my 252 reciever and Pro 600 back into the combine and I am not getting power to the Reciever. AFS support said that removing the Nav II shouldn't have anything to do with this but it apparently does. My dealer and I ended up using a separate cable to power the reciever and bring gps into the 600 through the serial port. Well I have gps to the 600 now but I am concerned that there might be other issues that I won't know about until I go to the field (10 days or so). How can I be confident that my yield monitor is going to work properly with this set up?
Thanks for any advice you may have for me.
Phil Jacob | |
