Search Forums | Classifieds (109) | Skins | Language
turn signal and running light circuit is shorted together?
simple man
Posted 11/29/2024 10:15 (#10987434)
Subject: turn signal and running light circuit is shorted together?
This problem is on an older KW. When turning on the running lights, the right signal light stays on constant. When turning on the right turn light, all the running lights flash as a signal light. Pretty sure that the two circuits are connected together. I have tried to isolate the problem .I disconnected all the rear lights from the main harness going to the rear of the truck. I haven't found any areas along the wiring that have been damaged or kinked. Anyone have ideas on where to track down the short?
Thanks in advance
