Search Forums | Classifieds (70) | Skins | Language
Forklift attachment for moving combine heads
leoduncan
Posted 10/30/2024 16:01 (#10944662 - in reply to #10944595)
Subject: RE: Forklift attachment for moving combine heads
That is what I have, if I understand your description
My mover slides on my forks with tubing but the mover has to be at the end of the forks. If I slide it closer to the mast the forks protrude out and have to go through the head throat. Generally there is either no room or it won’t die through the reel or there is some sheet metal that will hit before the mover engages the lifting point of the head
I need to move the head closer to the mast so I have the force to lift the load
