Posted 8/20/2009 14:48 (#818153 - in reply to #816535) Subject: Re: EZSteer 500 on Case STX settings?
north central SD
We have a CIH 9330 and originally had the antenna on front of the cab which was behind the axle. In the paperwork we got, Trimble says to put it right over the axle but I made a bracket to extend it 9 inches in front of the axle now. It works much better this way. Also angle per turn is 10 degrees which improved it a little.
