Posted 7/25/2009 14:33 (#787777 - in reply to #787757) Subject: Re: Payloader Leveling indicator
NE SD
When you pull the joystick to the left pull it all the way and it should activate the tilt feature. You'll feel some resistance but just keep pulling past the "hump" then let the joystick return to the center. The lift side has never worked right on our 544G.
