NW Ohio,near Findlay | First thing to do is check air flow at radiator, transmission cooler, your problems I think are heat related. Then check your filters in the transmission, where ever they are. I assume there is a suction screen in the bottom of the case, others will know how to clean it, I do not know anything about the hydros.
I have posted before, I'm not a full hydro fan on a dozer, I guess just to old to get use to them. Have run them a few hundred hours, just don't like the system. Turning with a load while under power is the main reason most operators like them. But they can be a very expensive system to repair and your application, constant pulling under maximum load. Only easy time is backing up for next run, but you are probably reversing full speed, and that would be lugging hydro motors too. Good luck finding you problem.
