swmn | Need more info. Is the 750 a stand alone display just sending NMEA to the Raven, or is it running some kind of guidance system? Where do you have the cable hooked up to run from the Trimble to the Raven? I'm assuming you're running Autopilot since you came from a tractor with a Pro700 but we'd need to know for sure because it does make a difference. | |
