| Been planting with a FMX running EZ Steer for several years and use "Nudge" to move the infill line over when starting on a field to make sure there is no gaps between the field and the ends.
Now were using a tractor with integrated steering and on the FMX we no longer have "Nudge" in the Ez Steer menu, it has been replaced with "Trim" in the Nav Menu.
Is "Trim" supposed to be the same thing as "Nudge"?
Been having problems with it not switching from 10"R to 10"L when turning around and I'm starting to wonder if its not the same thing as "Nudge".
For example, when using 10" L to make the initial infill pass when I turn around it stays on 10"L and now we end up with a 40" wide row between passes instead of the desired 20".
