Northern Ohio Grain | Turned out good. The cable I used only uses the signal and ground pins on the raven 3 pin connector as the centerline 220 had a separate 12 volt wire running to it on the opposite side 4 pin connector. Also double checked them back to the 9 pin serial port and they are correct with the signal pin on the raven to pin #8 and the ground pin on the raven to pin #5. Thanks again for all the help.
(20220507_115338 (full).jpg)
Attachments ---------------- 20220507_115338 (full).jpg (243KB - 71 downloads)
