Posted 6/16/2009 18:30 (#747380 - in reply to #747137) Subject: Re: mennoboy - 4430 Command start ?
Manitoba, Canada
i was just talking to Sean Neufeld 2 min ago on the side of the road. small world. Yeah i just wanted either idle or fast idle on the tractor, but if you are wanting infinate control you could use a linear actuator. sompething like this: http://www.dcactuators.com/Detail.asp?Product_ID=301.100_6102T if you want you could just mount it to the throttle in the cab and put in a rocker switch.
