Van Dyne, WI | How much closing wheel pressure do you guys typically run? I have a JD 1750 planter and work all tilled ground. I have one Dawn Curvetine and one rubber closing wheel. I always run in the first position with the least amount of pressure. Seed trench is closed and not a problem but now that my corn is starting to emerge it looks a little uneven. There was good moisture but our heavy clay is always a little lumpy. Was planting yesterday for a neighbor with the tractor with EZ steer, I had time to observe the planter a lot more, seems the closing wheels are "bouncing around a lot." I'm always worried about too much down force but maybe I need more? What's your experience as the best way to tell how much closing force is enough? | |
