I've got a Deere F725 front mount. I like it better than any zero turn I've driven. I've got a couple places where the ditch is washed too deep to mow down in it. I just back around and hang the deck out over it to cut it. It'll turn a small enough circle I can go right around a light pole. It's also got a load and draft type control if you have trouble climbing hills if the grass is slick. It'll slightly raise the deck to put weight on the front wheel and away we go. |
