| A couple of years ago I was having similar problems so we replaced the engine terminator but I went backwards. It had the 3 pin connector type and I put the older triangle black block back on. yesterday I noticed that the A post had the older block still mounted, but there was an adapter harness and the smaller 3 pin terminator. I'm assuming both terminators had been updated the new, improved setup. At this point I'm going to replace the engine side with a newer 3 pin (and adapter harness) and replace the 3 pin terminator in the A post just in case.
With the software I was hoping to move things like the throttle and hydraulic "levers" and see the values change, etc.
Someone, long ago, mentioned installing another ground from the seat and there may have been a service bulletin. Couldn't find a bulletin, but it sounds like a good idea. Any idea where to connect on the seat frame (or arm rest) and where is a good hole to get down to the battery? thanks | |
