Search Forums | Classifieds (222) | Skins | Language
Trimble Nav II NMEA out to JD 2600 help
P1402
Posted 10/13/2021 21:01 (#9267640)
Subject: Trimble Nav II NMEA out to JD 2600 help
I’m having trouble getting NMEA out of a trimble Nav 2. I have done it with a Case branded nav that had a deutsch connector, however this one has a db9 serial that they call a laptop connector in a harness coming out of controller, I was under the impression i could use that but have had no luck. Any help would be appreciated. As I said i’ve done it on a pro700 case nav2 so understand the settings needed to communicate with the 2600 for that, the trimble version of this seems to be throwing me for a loop. I also bought the ag express harness to run nmea out of 372 but can’t seem to get that to work either. Either method would be OK with me. Thanks
