Search Forums | Classifieds (1) | Skins | Language
JD 7810 shift issue
moobeast
Posted 9/14/2021 20:23 (#9220538)
Subject: JD 7810 shift issue
Earlville, NY
7810 with 19 speed powershift, if you put it in reverse higher than 4th, tractor goes into neutral and transmission light comes on. Have to put it in park before it will go back into any gear. Ideas? Is there a sensor of any kind under the shift lever/throttle panel cover? The cover was replaced a week or two before shifting issue popped up.
