Southern Ontario | Jd7730 - 8/6/2021 19:26
I am sure they are both good and high quality tractors and that the models are comparable. My thought is that if you choose the Kubota it needs to be at least 25-30 percent less money up front because the JD will have higher resale value, a better dealer support network with better parts availability.
Definitely cheaper to buy than JD and will fetch the same and maybe even more here in Souther Ontario.
This is where Kubota cut its teeth and as someone else said Kubota makes the whole tractor, JD in this hp range contribute just the paint and name. |
