NW Ohio | First, is your TMX unlocked to RTK? If not and wanting to use the Ag25 internal globe it will not work RTK unless unlocked.
Second, there is a difference between NMEA and RTCM. RTCM or CMR is a correction/RTK signal. NMEA has many different sentences but a common one is GGA which supplies the system with Lat/Lon/Alt. If using WAAS, the GGA is to WAAS accuracy, if using RTK the GGA is RTK accurate. | |
