Posted 5/13/2009 12:23 (#712225 - in reply to #712202) Subject: Re: Insight quit painting
North Central Ohio
Dingleberry did you load a new field after moving down the road for 20 min or did you spray it with the same field ID as the first 2 small ones , was the arrow on the screen on the insight representing you ?,if you did not load a new field after moving, it probably did paint ,it's just zoomed out so far you can't see it
