Posted 6/14/2021 21:59 (#9059356 - in reply to #9058750) Subject: RE: Best step on poly wire posts?
SC Mo Ar line
I use the fiberglass stepins with the molded on clips. I can run 2 strands of poly quite easily. I use extension cord reels. The big advantage to the fiberglass posts is I can use a hammer on them in our dry summers. The others won't go in the ground.
