I have a Canon printer/scanner and a Canon scanner. Both of them have software that allows you to scan to a file. A pdf file. When scanning to a pdf file they ask if there is another page. Answer yes and insert the next page to copy. I suspect that the Lexmark will have software that allows the same thing. When you scan you might set the dpi to 150 which should be adequate. It should create a smaller file. A little expirmentation might be in order.
