Posted 8/1/2018 13:13 (#6905586 - in reply to #6905536) Subject: RE: jet pump
South Texas
So it is pumping 260 psi plus whatever flow line losses. Anyway that shouldn’t make it trip out.
Check your voltage at the pump with it running. How big of wire goes to it and how long? Too small of wire will make voltage lower which makes amperage higher which overheats the motor.
