Boone, Iowa | I spent part of the day on JDParts online and think I have all that is needed. The cylinder lift arms that the tire and lift cylinder hook to, nned to be changed out. One is slotted, where the cylinder attatches and the other 7 arms are a different part number than the slotted arm and the 7200 arms. The lift cylinders are reused. You have various hyd hoses and fittings that may be cheaper if sourced out. The expensive parts are:
manifold $1960
pressure relief valve $1205
(8) rephasing valves @$115 ea $915
slotted lift arm $660
(7) regular lift arm @ 540 ea $3785
_______
$8525
The other $2280 amount to hoses and fittings. Alot of these hoses are to be fabricated, according to parts listing. The website gives fitting type and length for most of the hoses.
