Posted 7/1/2016 09:15 (#5385167 - in reply to #5384839) Subject: RE: JD 985 field cultivator wings not level, I got an idea...
Central Illinois
Does your 985 have a common rock shaft across the center section from wheel to wheel? If it does, you may have twisted it. 1 wheel is higher than the other and it doesn't allow the self phasing cylinders to flow oil out to the other cylinders.
